It is currently Mon Jul 06, 2026 5:43 pm
 Post subject: Tow Bar
PostPosted: Wed Sep 24, 2008 11:02 pm
I am thinking of fabbing up a tow bar for my Dart, and the materials/welding part of it is no problem, but I have 1 concern. How do I keep the tires on the Dart from turning while the tow vehicle is going straight? Do the tires naturally go the way I am leading? Or will they want to turn to the side? Anyone have any experience with this?
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Wed Sep 24, 2008 11:18 pm
well you can tow it backwards in neutral or have someone steer the car for you its not good for the transmission if you dont take out the drive shaft... i took 2 L shaped pieces to go around the bumper welded chains on the ends of them drilled holes for bolts and hooked them to a to a trailer hitch it wasnt difficult as long as your a good welder
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
PostPosted: Thu Sep 25, 2008 12:34 am
Don't lock up the steering.
The tires track automatically when you're going forward.
But when you're go backwards the tires get terribly confused......
PostPosted: Thu Sep 25, 2008 6:20 am
Might want to do a search on this as I remember a year or so ago this was a problem for someone here on the board. They couldnt get it to track straight.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
