It is currently Sat Nov 14, 2026 7:26 am
 Post subject: different carter bbd
PostPosted: Thu Mar 27, 2003 11:58 am
I found another BBD. I think it's older type. It has flat accelerator pump shaft.
Here is picture of it
http://www.slantsix.org/articles/choke- ... rvice1.jpg
I would like to have adjusting instruction for this carburetor if anybody knows how to adjust it and if it's possible to adjust. Also there was no accelator pump arm installed, I do not know why , but I made one by myself, problem is that I do not know what is correct length for it.
Sorry, my english is not very good
PostPosted: Thu Apr 03, 2003 1:13 pm
No answer???
Is my english really so bad.
PostPosted: Thu Apr 03, 2003 2:45 pm
I have one of those carbs sitting on my bench at the moment waiting for a rebuild, i'm not sure if they are any "bigger" but they sure are different!
anyways i dont know of the adjustments as of yet, i'll know tommorow if you can wait till then (i'll have my rebuild kit tommorow at 9am)
and know your english is just fine :)
Justin
PostPosted: Thu Apr 03, 2003 2:46 pm
would help if i logged in first
:roll:
Justin
PostPosted: Fri Apr 04, 2003 11:50 am
Site Admin
:roll:
Justin
Justin,
You don't need to log out. Just close the browser when you are finished.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Fri Apr 04, 2003 5:36 pm
Thanks Justin
Is it possible to copy me that manual, which comes with rebuild kit ?
I also still want to know, what is correct length for the 'Throttle connector rod' ( part number 4 in that picture-- http://www.slantsix.org/articles/choke- ... rvice1.jpg). When I get that carb it was missing that part, and there was other damages also which i have already repaired.
It might be that i'll never need that carb, but I would like to make it work and try it .
The other newer Carter BBD I have, is now rebushed and I also had to make new throttle axle, because the original was too much worn. I'm now adjusting it and I will let you all know what is the result.
PostPosted: Fri Apr 11, 2003 7:02 am
I still need that rod length.
Joug
 Post subject: Rod length
PostPosted: Fri Apr 18, 2003 1:32 am
The rod is 90mm long between to locating bends.
Hope this helps.
PostPosted: Fri Apr 18, 2003 3:16 am
Thank you very much
PostPosted: Mon Apr 21, 2003 4:17 pm
Site Admin
I may have a rebuild sheet. Let me know if you still need it.
PostPosted: Tue Apr 22, 2003 12:36 am
Thanks Chuck. I still need it.
PostPosted: Fri May 02, 2003 12:14 pm
Site Admin
Joug,
I have the instructions for you in JPG format. The problem is that these files are large, about 1.3mb total. You also can't print them out from a browser because the page size is large. If I reduce them there will be a significant loss in quality. You will need some kind of photo editor to print them. What do you want me to do? I can send you a zipped up file of the 4 pages but it will take a long time to download if you are using a modem connection
PostPosted: Sat May 03, 2003 12:56 am
Chuck
I have no problems with jpg's and there is enough space in my email. So if you can send them to me , I will be very happy.
Joug
PostPosted: Sat May 03, 2003 10:31 am
Site Admin
OK, just let me know if there is a problem.
PostPosted: Sat May 03, 2003 4:30 pm
Thank you Chuck.
No problems and very nice to have so good quality scanned instructions.
Joug
Users browsing this forum: Amazon [Bot] and 3 guests
