It is currently Wed Jun 10, 2026 1:25 am
 Post subject: Lift kit
PostPosted: Thu Apr 09, 2009 4:17 pm
Does anyone know where I can buy a lift kit? I've kinda been looking but if anyone knows a website it would help. looking for about a 2" lift kit
-- Mister Perkins --
Pictures of my truck
http://www.cardomain.com/ride/3257131p
PostPosted: Thu Apr 09, 2009 5:19 pm
Isn't that truck 2WD? Raising the ride height of a vehicle is the wrong way to go for on-road handling.
PostPosted: Mon Apr 13, 2009 3:45 pm
I'm not worried about on road handling. it drives 1/4 mile a day to and from work. I just want it higher off the ground. I'm going to get a set of leaf springs with more springs too so i can haul things around. I am just looking for some suspension blocks to lift the truck up a little bit. Along with new springs and sway bars it will be alright.
PostPosted: Mon Apr 13, 2009 5:41 pm
I bought a 4'' Rancho lift for mine for $600 and it was perfect because I didnt have to extend anything. I think I got it from JC whitney. you might have to buy longer shocks though. The ones I bought were about $75 a
pice but they have cheaper ones.
PostPosted: Mon Apr 13, 2009 5:52 pm
do you have any pictures of it? Just curious how a 4" lift looks.
PostPosted: Tue Apr 14, 2009 1:06 pm
[img]http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=97281937&albumID=2721122&imageID=43781508
These more there too.[/img]
PostPosted: Wed Apr 15, 2009 5:55 pm
well, instead of buying a lift kit I am just going to go down to the segal and son iron works and get a piece of square tubing, drill a hole for the center bolts, new u bolts and jack it up myself. front wise, I am going to replace the springs with heavier springs and new struts all around. I'll post pics soon of before / after
PostPosted: Wed Apr 15, 2009 6:38 pm
That should work too. All mine is front spring and rear blocks anyway. Just be careful that you don get too much axel wrap.
PostPosted: Thu Apr 16, 2009 6:00 pm
yeah. I just want to get it lifted up a little bit. rides too low right now, plus front/rear shocks are shot and it bottoms out. I might get some more leaf springs to add to it so I can haul whatever I need around. plus the front springs are shot anyways. I wonder what would be some good springs to install up front? Are the OEM new springs for the dodges pretty stiff when they are new?
PostPosted: Fri Apr 17, 2009 6:12 am
Springs are fine "new" but use ESPO or even JC Whitney. Why not just fix your shocks and springs and not worry about the band-aid of a lift kit?
Also if you are buying new springs just have them made with a higher lift built in.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Apr 17, 2009 4:37 pm
I'm not trying to band aid my truck with a lift kit. I dont like how low its sitting right now. I just want it lifted up a little bit and get the suspension fixed properly. If I can save some money by making my own blocks, that what I'll do though. I just wanted to know as far as the front if I should buy heavier springs or if the OE / Remand are alright to install. The springs that are on the truck right now have 186,000 miles on them. Time for replacement
PostPosted: Fri Apr 17, 2009 9:37 pm
Site Admin
Well, as mentioned above, JC Whitney might be a good choice. They had/have a special running on springs. I just picked up a set of rear leaves for the Valiant 'fer cheap. OE spec. $137.96 delivered. The poor UPS guy looked beat carrying them up on the porch. :lol:
I did Rancho Variable rate front coils on a 2wd I owned years ago, and it was a new truck.
I had a set of rear leaves made by a custom outfit in Portland OR. Added air shocks, and overloads. I could carry anything I could reasonably fit in the truck bed. handled remarkably well after that! :lol:
2¢
CJ
