It is currently Sun Jun 07, 2026 8:32 pm
 Post subject: Engine that shuts off
PostPosted: Wed Jul 01, 2009 3:23 pm
I would appreciate anybody who can give me clues about what it can possibly be happening to my car that many times when I turn, or even sometimes when I brake it, the engine shut off and I have to restart it in the middle of the intersection. It has a recent remanufactured (cleaned) carburator and a new fuel filter.
PostPosted: Wed Jul 01, 2009 3:32 pm
Just let me add that mine is a duster with a slant 6, simple w/o modifications, as original. Thanks.
PostPosted: Wed Jul 01, 2009 3:36 pm
Sounds like your carburetor may be out of adjustment, I'd look at your mixture screws are set and start there. Doubt if timing would have any play into this, I'd also double check to see if you got any intake vacuum leaks causing a change in the A/F mixture.
1973 Plymouth Valiant
1953 Dodge Panel
PostPosted: Wed Jul 01, 2009 4:37 pm
If you bought a remanufactured Holley model 1920 it's probably junk. Actually, it's almost certainly junk.
PostPosted: Wed Jul 01, 2009 4:46 pm
Does the engine stall as you attempt to give it gas? (throttle opening)
Or will the engine stall if it is just sitting there idling, with no throttle movement?
PostPosted: Wed Jul 01, 2009 4:58 pm
Thanks to all of you. Yes, it shuts off when is idle. And yes it's a Holley 1920.
PostPosted: Wed Jul 01, 2009 5:15 pm
It actually does not take time idling for shutting off, but it shuts off at the time when I'm turning or as soon as I break and it stops still.
PostPosted: Wed Jul 01, 2009 6:06 pm
I mean I don't have to hit the gas pedal for the engine shut off, though that has also happened.
PostPosted: Wed Jul 01, 2009 7:36 pm
Float level?Mark
PostPosted: Thu Jul 02, 2009 7:42 am
Does this car have power brakes? Could be a leak at the brake booster?
PostPosted: Thu Jul 02, 2009 10:50 am
Will it idle at all when warm?
(The carb could have a plugged idle circuit)
PostPosted: Thu Jul 02, 2009 1:36 pm
What RPM does it idle at out of gear and in gear?
PostPosted: Thu Jul 02, 2009 5:56 pm
Car Model: 87 B150, 1970 Valiant 4-door
I second that.
PostPosted: Fri Jul 03, 2009 7:04 am
Car Model: 1968 Plymouth Valiant 100
I'm not trying to make a smart remark but why would the brakes have anything to do with the car shutting off? Are they wired to the ignition or carb? Just asking. -Dan :?:
1968 Valiant 100, 4dr, 225 - FOR SALE TO A GOOD HOME!
PostPosted: Fri Jul 03, 2009 8:48 am
If he had power brakes, the vacuum assist can lower the idle even more if it is already too low and kill the engine. Sometimes the check valve on the power booster will go bad and it's like unplugging your PCV line.
In other words a big time vacuum leak! :cry:
