It is currently Thu Jan 01, 2026 10:15 pm
 Post subject: forged dish pistons
PostPosted: Thu Sep 03, 2009 6:09 pm
Hello gentlemen.
Im looking around for pistons. Its kind of hard for me to find because im not really knowledgeable about slant sixes.
What options are out there for going with FORGED DISHED pistons for the slant 6. I have a 225.
Im going turbo so im looking for the less static compression possible but still aluminum forged.
Thanks
PostPosted: Fri Sep 04, 2009 5:18 am
Any piston manufacturer can make slant 6 pistons. Just choose who you like. Wiseco/K1 has some pistons and rods on the shelf. As far as I know there are no other "off the shelf pistons".
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Sep 04, 2009 8:41 am
Thank you 8)
My concern is actually getting a forged like you said. "on the shelf"
because custom made are way more expensive.
PostPosted: Fri Sep 04, 2009 8:59 am
I had to have customs made because there wasn't anything "off the shelf" with a sutible compression height.
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Sep 04, 2009 10:01 am
But what was your target cr?
PostPosted: Fri Sep 04, 2009 11:38 am
One OTS (off-the shelf) option is to find some forged 2.2 4 cylinder Mopar forged flat tops and hang them on 6.7 long 225 con rods, that gives you 6.9 to 1 compression "on paper".
The special Wiseco "long rod" forged piston will also get you into that CR range.
PostPosted: Fri Sep 04, 2009 11:55 am
8.2
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Sep 05, 2009 5:37 am
I bought custom forged pistons from Ross. I ordered 6, they shipped me 8. lol
PostPosted: Sat Sep 05, 2009 11:09 am
why not get the Wiseco pistons,put them on the 225 rods and shave the head,block to get your 8.2,,just a thought.Mark
PostPosted: Sat Sep 05, 2009 12:44 pm
That would work but I wanted new rods to be safe with a lot of boost.
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Sep 05, 2009 3:33 pm
What is the stock comp ration on the 225 anyway?
Im looking for forged low comp on pistons..
PostPosted: Sat Sep 05, 2009 3:43 pm
I believe they are rated 8.2 but given machining tolerances from the factory, I would guess they are in the 7.5 to 8.0 range.
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Sep 05, 2009 8:37 pm
I would check with Wiseco,see how much you could take off the top of their earlier, heavier,guessing thicker pistons.
I do have a set of those new in the box that I wont be using,think its worth a call.Then you could use the new K1 rods and set the engine up as a low compression,long rod motor.Mark
Users browsing this forum: Google [Bot] and 11 guests
