It is currently Fri Jan 02, 2026 7:34 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Thu May 12, 2005 8:35 am
Soft engine mounts can also cause this
PostPosted: Tue Nov 10, 2009 7:26 am
Check the reverse band adjustment. May be that or a reverse servo sticking in the bore and then releasing all at once.
Cecil
Hi there,
Can anyone tell me what is "reverse band" and how to adjust it?
Thank in advance!
PostPosted: Mon Nov 30, 2009 2:44 pm
A reverse band is located inside the transmission at it's rear. It is used to apply the low/reverse drum and is adjusted after the pan has been removed by loosening the lock nut and rotating the threaded stud, thereby tightening or loosening the band.
"You know a car is really yours when you've touched every fastener on it." -David Freiburger
PostPosted: Wed Dec 02, 2009 12:52 pm
After changing rear ends from 8.25 to 8.75 and having the drive line cut to size, my 71 Demon developed a clunk going into reverse. It turned out that I had measured the drive line to short which left the yoke sitting outside the tranny to far. At this point I believe the clunk came from the wobble effect of the yoke not being properly seated into the tranny. Upon having the drive shaft cut to a more precise size, the clunk went away. Measuring the drive shaft to it has an exact 3/4 inch tolerance to the rear end is key.
PostPosted: Wed Dec 02, 2009 1:38 pm
Neither of mine go clunk when I shift into reverse. Should I be worried?
