It is currently Sat May 23, 2026 3:43 am
PostPosted: Mon Feb 21, 2011 3:13 pm
Car Model: 1966 DodgeDart
What plugs do you recommend for a '66 225? I am currently bringing my mother's Dart back to life. Going thru carb Carter BBD, Fuel pump, Distributor. It has Autolites in it -They look good but I want everything fresh when I put it back together. I thought I read somewhere the washer on the plug should be removed if the motor has the Oil tubes around the plug. Is this correct & why? [/img]
PostPosted: Mon Feb 21, 2011 6:08 pm
Anything but Autolites. Seriously, for some reason, they just do not ignite anything. I have great success with Champion or denso... champion now makes a truck plug and a heavy duty plug that should last a long time. Dunno if they make it for the SL6, though. My next attempt at plugs is to check out E3's and / or Halo plugs.
PostPosted: Mon Feb 21, 2011 8:49 pm
NGK's Do a search on forum as this subject has been discussed many times.
Thanks Mike
PostPosted: Tue Feb 22, 2011 7:12 am
Thanks found the info I needed .I am glad I came across this site. Wish i would have found it earlier!!!
PostPosted: Tue Feb 22, 2011 2:12 pm
Tune-up parts and technique suggestions, including spark plugs, in this thread.
PostPosted: Tue Feb 22, 2011 2:28 pm
Thank You Very Much.! I really appreciate this info!!. This has helped me tremendously and explains some of the issues I have had with this vehicle. I will continue to search thru here to find out more stuff I did not know . Thanks Again.[/img]
PostPosted: Tue Feb 22, 2011 4:18 pm
Welcome 66. There is a gold mine of information on this site. If you have time, check out the general-info articles, and also the FAQ's at the top of each section.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
