It is currently Thu May 07, 2026 1:19 am
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Sep 07, 2011 5:36 pm
All the spark plugs are already out and the piston stop is in #1. Also removed all the pushrods from cylinders 2-6.
It's still a PITA to turn over and seems to get "stuck" for no reason.
That crank sprocket is super tight. I'm afraid it's going to break as I'm pulling it off. Any suggestions?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Sep 07, 2011 8:31 pm
measure the crank snout to .0005 clearance...
then take the sprocket to a machine shop and have them hone it to that spec...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Thu Sep 08, 2011 10:29 am
Well after trying for 3 hours this morning and shearing a grade 8 bolt in my puller, the crank gear hasn't budged. Looks like it's forever stuck at 2* advance. Any suggestions on degreeing this thing with it advanced already? I know I'm going to have to use offset bushings in the cam sprocket if I want any changes.
82 D150-225/727
PostPosted: Thu Sep 08, 2011 11:19 am
I would fix any issues have first..crank bolt etc..
slant six's RULE!
http://www.usajon.com
PostPosted: Thu Sep 08, 2011 11:42 am
I don't have any other issues besides trying to get this cam degreed.
82 D150-225/727
PostPosted: Thu Sep 08, 2011 12:25 pm
exactly... get the bolt out...
did you ever finish degreeing it to see where the cam is actually at?
you might be able to put heat to the sprocket... did you lube the snout?
PostPosted: Thu Sep 08, 2011 12:36 pm
The bolt is out, it's been out.
I tried the heat thing using a bottle torch and map gas. That's when it sheered off one of the arm bolts on the puller. I lubed the snout with engine assembly lube when I put it on. It will not budge ANY from it's installed position.
No I haven't gotten it degreed yet, still waiting on my dial indicator to arrive from summit. Also ordered 1 mechanical lifter to use for degreeing purposes. I did get my degree wheel and crankshaft socket this afternoon. Used the wheel and a piston stop to find absolute TDC. Got the engine sitting there until the dial indicator arrives.
That crankshaft socket was well worth the money. Beats the hell out of the bolt, nuts, washers technique.
82 D150-225/727
PostPosted: Thu Sep 08, 2011 5:37 pm
so how much effort did you use to get it one? the sprocket
PostPosted: Thu Sep 08, 2011 5:42 pm
kid why not do a youtube sometime of this. there is NONE as yet..
it is needed.
slant six's RULE!
PostPosted: Thu Sep 08, 2011 11:33 pm
you mean of degreeing a cam?
PostPosted: Fri Sep 09, 2011 2:59 am
Yes, I'd love to see a you-tube of timing chain replacement / degreeing cam on a slant six.
Once you solve your issues, you could repeat the process in probably a matter of minutes... would make for a great video to link from the "How To" section on this board.
- Mac
PostPosted: Fri Sep 09, 2011 7:29 am
Didn't use hardly any effort at all, I heated it up and slid it on.
82 D150-225/727
PostPosted: Fri Sep 09, 2011 7:54 am
if i had a motor sitting on a stand i would....
PostPosted: Fri Sep 09, 2011 7:58 am
After I get this motor successfully degreed I will run back through the steps on a video.
82 D150-225/727
PostPosted: Fri Sep 09, 2011 12:21 pm
so how much effort did you use to get it on? the sprocket
ok first of all you shot yourself in the foot by heating it an installing it... it is locked on there unless you get it really hot... but by doing this it may ruin the sprocket... if it is seated all the way then i guess you can leave it
or
call jp for a bottom sprocket, cut the old one off... which is what i would do...
then do as i said above and have the sprocket honed to the correct ID..
also above you said it gets stuck... did you rebuild the engine? is the flex plate on it?
