It is currently Mon Oct 12, 2026 6:58 pm
 Post subject: water pump install?
PostPosted: Thu Mar 14, 2013 2:53 pm
Can I use black permatex # 16B, item # 81158, If not let me know the correct stuff, thanks, Dana
 Post subject: Uh...
PostPosted: Thu Mar 14, 2013 3:29 pm
Yes you could or orange/bronze RTV...but you should be able to install the pump strictly with the gaskets it came with if you cleaned the block mating surface. Are you reinstalling a used or previously installed pump?
p.s. when installing make sure to get the hose the head the right length and install first with hose clamps before installing the pump itself...
 Post subject: W Pump.
PostPosted: Thu Mar 14, 2013 3:42 pm
D, My new wp does have the gaskets and I was going to put a little bit on each side. Am I right or wrong?
 Post subject: No..
PostPosted: Thu Mar 14, 2013 4:22 pm
It's not needed, but if you are going to make them stick to keep them in place for a quick installation (less to 'juggle'), go for it, it won't hurt your install.
-D.idiot
PostPosted: Thu Mar 14, 2013 4:42 pm
Thank you
PostPosted: Thu Mar 14, 2013 6:30 pm
I used rtv on the block side because of corrosion pits. The rest was dry.
PostPosted: Fri Mar 15, 2013 9:03 pm
I use grease,helps seal and makes removeing them later a breeze,no stuck gaskets to scrape.Guzzi Mark
PostPosted: Fri Mar 15, 2013 10:36 pm
I prefer grease too.
