It is currently Tue May 26, 2026 9:46 pm
PostPosted: Thu May 16, 2013 11:23 am
Car Model: 1963 Dodge Dart convertible
Hi guys, more questions for 904 disassembly.
I am trying to remove the tail shaft but for my 63 which uses the trunnion there is a flange which needs to be removed. I have a 1 1/16" socket which is too small for the nut. Can anyone confirm the size of the nut, 1 1/8" or 1 3/16"?
Also the service manual refers to a funky tool, C-3381, to hold the flange so it does not rotate. Looks like I can use some angle iron with a couple of holes drilled in it to hold the flange to prevent rotation. Anyone had to confront this?
Thanks folks.
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Thu May 16, 2013 11:49 am
Forgot to include the picture.
http://www.myfigtree.com/flangnut1.jpg
PostPosted: Fri May 17, 2013 5:18 am
Yeah, I just did as you said, a piece of scrap metal with two holes, worked fine.
PostPosted: Fri May 17, 2013 8:38 am
Thanks Lancer, do you remember the socket size? 1 1/8"11?
John
PostPosted: Fri May 17, 2013 12:36 pm
6 Pack Dart
I measured the nut on 3 speed manual it is 1 1/8"
Richard
PostPosted: Fri May 17, 2013 1:21 pm
Thanks a bunch fopar!
