It is currently Thu Jan 01, 2026 5:05 pm
 Post subject: Head gasket sealer?
PostPosted: Sun Jul 21, 2013 8:01 pm
Is sealer necessary? Using a Corteco head gasket. Could be wrong, but from examination don't think it has any self-adhesive. It feels almost tacky on handling - maybe it doesn't need any? FSM states to use some: doesn't say one side or the other. Have read from others they use none. This gasket is sealing a milled head and decked 225, so they're surfaced, true and ready.
PostPosted: Sun Jul 21, 2013 8:48 pm
No modern head gaskets I know need (or should have) sealer.
 Post subject: Composite head gasket...
PostPosted: Sun Jul 21, 2013 8:49 pm
Nothing aftermarket is a shim style/OEM gasket. Felpro,Victor,Corteco are basically install and torque, no prep needed other than a clean mating surface.
PostPosted: Sun Jul 21, 2013 11:08 pm
Doc uses copper sealant on the spark plug lip side of the head (i believe).
70 Plymouth Valiant 4dr
PostPosted: Mon Jul 22, 2013 10:42 am
Actually... I use a little high temp RTV along the outer lifter Gallery edge, just to prevent any oil "weeping" at that joint.
PostPosted: Mon Jul 22, 2013 11:33 am
Car Model: 1964 Valiant V200
Both sides? All of the high-mileage slants I have owned weep right there, but the last one I rebuilt (with no sealer and a fel-pro gasket) never seeped in 50,000 miles of driving.
