It is currently Sun Dec 28, 2025 9:52 pm
PostPosted: Wed Sep 30, 2009 10:07 pm
Gday guys, on the topic of manifolds here is one on a VC Valiant (1966/67) here in Aust.
http://www.youtube.com/watch?v=W_3Lg07A9Fs
cheers
PostPosted: Thu Oct 01, 2009 8:46 pm
Here's a pic of that setup.
P.S. Welcome aboard Bernie. :)
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Fri Oct 02, 2009 5:08 pm
Poser
Progressive? Tell me about the carbs. Cfms. Welcome!
PostPosted: Sat Aug 03, 2013 4:46 pm
i picked up one of these manifolds on the cheap and the guy threw in 2 matching carter bbd carbs that fit. Sounds like a lot of carb for a stock 225motor. Has anybody got these to run with with twin 2barrels?
PostPosted: Sat Aug 03, 2013 5:01 pm
Welcome aboard Brian. The BBDs are not progressive and might be a bit much, but if ya back off the accelerator pumps a little,
maybe not. My SWAG. Anyone actually done this?
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Sat Aug 03, 2013 5:06 pm
Site Admin
Welcome! :D
There are folks with more carburetor. Signal may be a bit low, but with a bit of tinkering, they should work fine. What did they run on the dual 2bbl's in Africa?
Where does that put CFM rating? Probably just under 600 CFM. The two barrels were rated at 4" or 2"? I can never remember. They are rated at a different differential than four barrels. Not really a level playing field! :lol:
CJ
PostPosted: Sun Aug 04, 2013 4:28 am
Where's the brake fluid reservoir? :lol:
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sun Aug 04, 2013 9:56 am
On the drivers side... :wink: it's a RHD downunder car and you are looking at a remote booster
1967 VC Valiant
PostPosted: Tue Aug 06, 2013 7:31 pm
Those carbs on the VC look like progressive webers,similar to what I'm doing but I've got DFEV carbs which are mirror image to those ones....good to see it runs on that YouTube video,it give some reassurance!
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 4 guests
