It is currently Wed Nov 11, 2026 5:28 am
 Post subject: I Need Your Help!!!!
PostPosted: Wed Jan 07, 2004 8:07 pm
O.K. here goes,
I bought an electronic ignition off e-bay. It is the 4-post type with the five wires. It also has the dual balast resistors. It came with an electronic voltage regulator. All good so far!!! So I put the dist. in and start to hook up the wires. I unpluged both plugs from my old balast resistor and connected all four wires together(which I think was wrong, because now they bypass any balast resistor). I then took those four wires and connected them to the loose brown and blue wire from the ECU wiring. The wire that goes from the positive side of the coil was left in place since I found it was one of the original four that I twisted together and connected to the brown and blue wires from the ECU. The other wires that are in the ECU wiring loom connect to the two balast resistor. The old single balast resistor is completely out of the car!! Lastly, I connected the black wire with yellow stripe to the negative side of the coil. I also changed to a Blaster 2 coil from MSD.
I started the car and it ran fine, but I heard the battery start to boil. So I put my meter on the battery and found that it was charging over 14 volts at idle. And when I reved the engine it would climb above 17 volts. Keep in mind I did not hook up the new electronic two wire voltage regulator, due to the fact that I have a single field alternator. Do I need a dual field alt. for the new regulator??
And remember the two blue wires that connected to one side of the original balast resistor, and the brown and blue that connected to the other side, and how I connected them together and attached them to the new brown and blue from the new wiring loom... Is this my problem??
Can someone lay this out Barney style for me...Thanks
Hellbent Rods & Custom fabs
PostPosted: Wed Jan 07, 2004 8:22 pm
yes. Your regulator is imcompatible with your alternator.
You should only see 13.8-14.7V dynamic voltage, regardless of engine speed. Variance is fine as long as it doesnt exceed these limits.
PostPosted: Wed Jan 07, 2004 8:23 pm
wait, I just remembered, chrysler alternators have different output from the universal figures above. I believe they are on the low side of these specs and fall lower. I think it's 12.8V on the low end. Goodluck
PostPosted: Thu Jan 08, 2004 12:46 am
How long was it running before it climbed to 17+ volts? Rember that computer controled (like my 94 daktoa) electronics take atleast 14 volts to run anything below that and it will die... and if you just started it within 5 min or so the battery could still be low? the charging system might still be trying to charge the battery... when you put a battery on charge it will boil... try taking it for a drive 15-20 min then hit it with the meter and see what you get?
Frank
PostPosted: Thu Jan 08, 2004 4:55 am
Negative. The voltage at the battery terminals should never exceed about 14.7 volts. If it does the voltage regulator is not doing its job. Could be a bad regulator or a wiring problem
 Post subject: Related Question
PostPosted: Thu Jan 08, 2004 7:36 am
I have a related question for a 73 Duster. It has a dual field alternator. Does it matter which of the two wires go on either field connector? I don't have any problems right now but didn't know if it did make a difference as long as the large black wire was right. I think the two I am talking about are green and blue? Thanks.
Mike
PostPosted: Thu Jan 08, 2004 7:52 am
The green and blue wires can go on either spade conector of the alternator, does not make a difference.
PostPosted: Thu Jan 08, 2004 3:21 pm
PLEASE DONT REPLY TO THIS MESSAGE ANYMORE
I'M A FREAKIN IDIOT
I FIGURED OUT WHERE I WENT WRONG. AND STILL CANT FIGURE OUT WHAT I WAS THINKING
PostPosted: Thu Jan 08, 2004 3:55 pm
*ducks*
Jeez ya know, if youd kept it a secret none of us wouldve known...
actually Im glad you asked the question, it made for interesting reading and there were a lot of informative answers. Glad you got things straightened out. :D
Users browsing this forum: Amazon [Bot], MadScientistMatt and 2 guests
