It is currently Sat Nov 14, 2026 8:01 pm
PostPosted: Thu Jan 08, 2004 12:52 pm
Hey guys,
Can I use my single field alternator with my electronic ignition??
Thanks
Hellbent Rods & Custom fabs
PostPosted: Thu Jan 08, 2004 4:24 pm
Yes, but I would use an electronic regulator. It looks similar to the original 66 regulator, but not as tall. Most parts stores sell them, if you ask for a regulator for a 66 mopar. Wires hook up the same as stock. If the cover is crimped on, that is the mechanical one, you don't want.
PostPosted: Fri Jan 09, 2004 10:54 pm
Charrlie wrote:
>>Yes, but I would use an electronic regulator. It looks similar to the original 66 regulator, but not as tall. Most parts stores sell them, if you ask for a regulator for a 66 mopar. Wires hook up the same as stock. If the cover is crimped on, that is the mechanical one, you don't want.<<
I would point out that the mechanical regulators I've seen are either held on with 2 rivits or 2 screws. But then again, mine is a '65.
Paul
