It is currently Mon Jan 05, 2026 10:11 pm
 Post subject: Carb Insanity
PostPosted: Fri Jan 16, 2004 4:28 pm
I just recently purchaced a remanufactured Carter model 2297 carb, 2bbl to replace my Holley carb. I don't think its a BBD as recommended, but it will fit on the manifold. ( i.e. Carb Leak post)
Anyhow, I am running into the same problem with this carb as with the last one... lack of info.
I can supply a photo if that will help the situation.
I am wondering about just general set-up of the carb.
Thanks
PostPosted: Fri Jan 16, 2004 6:19 pm
There is a lot of carb. adjustment info in this article, see the links at the end of the article.
http://www.slantsix.org/articles/choke- ... adjust.htm
 Post subject: Carb number?
PostPosted: Fri Jan 16, 2004 10:31 pm
Something's up with that carb number.
the 2295-2299 in the Carter series corresponds to the 1956 Mopar lineup...
PostPosted: Sun Jan 18, 2004 12:20 pm
Yes, the carb says 2297 on the body of the carb.
The Throttle lever doesn't have a spring on it, is that typical of the BBD carb?
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 12 guests
