It is currently Sun Dec 28, 2025 5:35 am
 Post subject: Pushrod Length
PostPosted: Thu Jun 25, 2015 11:13 am
So have milled 0.090 off cylinder head. Do I need shorter pushrods and if so, where can I get some?
keep it real, keep it safe
PostPosted: Thu Jun 25, 2015 11:40 am
http://slantsix.org/forum/search.php
PostPosted: Thu Jun 25, 2015 12:42 pm
If you are running a mechanical camshaft and lifters then I think you are safe to use stock pushrods if you have enough adjustment left on the rocker arm adjusters. If you are running a hydraulic camshaft and lifters then I think you arrested within the "free play" of travel of the lifter before it will bottom out.
But you should still do the math and check.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
