It is currently Sun May 17, 2026 3:58 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sun Feb 22, 2004 11:35 am
I guess I took to long on the post above, logged me out while I was writing it. Anyway, me above.
My car may be slow to sixty, but at least it's been reliably slow to sixty for more than thirty years.
PostPosted: Sun Feb 22, 2004 2:47 pm
The starter draws power direct from the battery - it's where the positive cable goes. It's the solenoid that goes through the ammeter. No fuse is there to protect the starter motor.
PostPosted: Mon Feb 23, 2004 12:27 am
Some words from the Chrysler corp. on fusible links:
Job
1965 Barreiros Dodge Dart. 225 / 4 speed.
PostPosted: Tue Mar 16, 2004 5:39 pm
I had the same problem .(no power to the car)
turns out my wiring harness got wet and shorted most of my inside wires with not one blown fuse.
you might want to check to see if all your wires are not melted together
riged it to work
I still need a new wire harness
PostPosted: Fri Mar 19, 2004 8:36 pm
You sure your harness melted just by getting wet?
I remember a forklift I worked on once, someone had installed a rear worklamp with a metal housing on the headguard and wired it direct to the keyswitch with no fuse, anyway some idiot backed into something and crushed the lamp, shorting the positive lamp terminal to the frame, and it smoked the entire harness. We had to replace every electrical component on the truck. Not one switch, gauge, bulb survived. Well the headlamps did but everything else burned. But I digress.
PostPosted: Sat Mar 20, 2004 4:41 pm
Dang, after that horror story I think I'm going to go back and check to make sure all my add-ons are well fused :lol:
