It is currently Fri May 15, 2026 12:07 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Tue Nov 27, 2018 5:06 pm
Funny, first post says source is "AARP"! I know these are old engines, but "AARP"?
PostPosted: Tue Nov 27, 2018 6:01 pm
FYI, all the posts before '82 Power Ram are over 4 years old; he resurrected an old thread.
Escape Velocity Racing
PostPosted: Wed Nov 28, 2018 2:28 pm
Car Model: 1982 Dodge w150 short bed 4 spd
If you mean the studs in the head that the intake and exhaust manifolds mount to, as far as I know they are all the same size. Granted that hasn't stopped me from using a longer stud in a pinch, then adding a washer or two between the nut and the triangle washer.
PostPosted: Wed Nov 28, 2018 2:31 pm
The studs are all the same size.
The key is making sure that the correct washer and fastener is used when re-assembling.
Fat circle washers and BRASS nuts go on each end on top, there is 1 fat circle washer with a regular nut smack in the middle on top, the remainder get triangle washers and regular nuts. Be sure not to over-tighten the manifolds.
~THOR~
PostPosted: Wed Nov 28, 2018 4:18 pm
Do you have questions about the quotes???
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
