It is currently Wed Jun 17, 2026 4:11 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
 Post subject: would this work
PostPosted: Fri Jun 25, 2004 11:36 pm
i'm thinking of building my own breather for my super six that way i'm not choping the ones i got around here apart but i'm not confedent it will work
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
 Post subject: breathe rite
PostPosted: Sat Jun 26, 2004 11:08 am
Car Model: '63 Dart GT Convertible
As a citizen of this earth you have the rite to build any thing you want. Assuming of course it is a legal item. In your case I think yo u would be just fine.
PostPosted: Sat Jun 26, 2004 9:03 pm
i don't care if it's legal or not i'd still build it
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
 Post subject: make it so #1
PostPosted: Sun Jun 27, 2004 6:51 am
sorry, i just thought that if you were asking if something would work, you might give a little more information as to what it is you are going to attemt. How can anyone know exactly how you are planning to do something if you do not give details on what you are thinking of. Asking if it can be built is like asking if YOU know what YOU are doing. Me, I can't build a box from wood. I tried it, made a good table. Someone who knows how could do it. Didn't mean to offend you.
PostPosted: Mon Jun 28, 2004 9:41 am
Are we talking about valve cover "breather(s)" or the air cleaner?
(some "blokes" call the air cleaner a "breather") :wink:
As for building either, it's just takes time and money!
PostPosted: Tue Jun 29, 2004 12:18 pm
we are talking about the air cleaner on top the carb i'm simply wondering if i will have problems with some of the lines that normally hook up
63ctcv i wasn't offended all i was saying is weather there are laws against it or not i would build anything simply for the bragging rights
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
 Post subject: Should work!
PostPosted: Wed Jun 30, 2004 2:49 pm
I never hooked up any vacuum lines to my air cleaner when I was using a Super Six.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Jun 30, 2004 7:20 pm
I took a Supersix Aircleaner setup and cut it and pop rivited a Holly 4150 set up in it and and have won races many times with this setup caint tell you the exiat setup because that mean ole Bagel Bomber might look at it.
But i will give you the combo on how to cut one tenth of a second off of your time without really trying. It will cost you 50 Dollars for the parts ,not the advise. :D :D Thanks Possum Parker
Hell Hath No Wrath Than A Possum Scorned
PostPosted: Wed Jun 30, 2004 9:59 pm
thats the whole point in me trying to build my own is to not cut a super six breather apart by now i think they might be getting pretty scares but thanks for the offer
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
 Post subject: ????
PostPosted: Wed Jun 30, 2004 10:06 pm
If you're using the typical BBD, and don't have A/C, then you could chop up all the 2 barrel 318 'pietins' you want...
Being a sheet metal worker, most guys roll their eyes when I bring a frankenstein into work to 'spot weld' back together...
Should grab some more of those from the junkyard and make some 'dual snorkels for guys here on the board...
PostPosted: Wed Jun 30, 2004 10:51 pm
i don't have one for the 318 only the slant
if i don't put the tubes in for the vacume hoses what do i do with them plug the with screws or loop them together and the theres the line that goes to the little breater on the tappet cover can i just leave that line off or does that need to be filtered
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Mon Jul 05, 2004 2:00 pm
i took a measurement and need a 2,9/16 inch pipe or something how hig could i go off the top of the carb in a truck i'm thinking of settin it up on a 2.5 to 3 inch adapter pipe or something like that
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Mon Jul 19, 2004 10:29 am
was looking and the adapter is not going to work so i'm either going to have to find a peice of pipe to fit or shape one out of some sheet metal
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Mon Jul 19, 2004 11:49 am
Easiest thing to do is cut up some other old air cleaners. These can be "super six", 318, or even some cheapo Taiwan aftermarket. Plug the vacuum port on your carb if it is not used, there's no need to plug anything on the air cleaner except for aesthetics. The oil breather on the valve cover will function just fine w/o anything hooked to it. It's simply where the air goes in the crankcase for the PCV (positive crankcase ventilation) system and it already has filtering material inside, but you may want to replace it with a new one if it is old.
D/W
If it ain't broke, fix it!
PostPosted: Mon Jul 19, 2004 5:04 pm
i'm trying not to cut the one i got apart might need it for another conversion my dad was doing in his van
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 6 guests
