It is currently Sat Jun 20, 2026 7:28 pm
PostPosted: Tue Jul 20, 2004 6:16 am
Hello I have both carbs which one offers better performance or is there much difference? My 65 has the holley & so far it seems to run smooth (off idle stumble) my 62 has the bbs & runs good. Just wanted to hear from the masses. Thanks, I don't plan on rebuilding the motor for some time I just want to cruise!!!!!!!!!
PostPosted: Tue Jul 20, 2004 7:53 am
I'm about to swap from the Holley to the BBS on a stock '72 /6... will advise.
D/W
If it ain't broke, fix it!
PostPosted: Tue Jul 20, 2004 8:15 am
My experience is that there has been more variation in individual carbs than between the two brands. A good 1920 will outperform an avg BBS and vice-versa. I can't say for sure, but I think the 1920s have given me better mileage as well.
A BBD (Supersix) would be a good upgrade in terms of performance, and shouldn't hurt mileage either.
PostPosted: Tue Jul 20, 2004 1:33 pm
The BBD "super six" swap has alwez worked well for me, and like Lou said, it won't hurt your mileage (in my case, it has always helped). I got this thing about keeping Kermit a bone stock 1 bbl, though...
D/W
PostPosted: Wed Jul 21, 2004 9:49 pm
This is very good timing...tomorrow I'm going to look at a rebuilt Carter 1bbl direct exchange. Being new to slant sixes I wasn't aware of these other choices...and by the way...what's a bbd and a super six? Sorry for taking you back to slant six 101, where I am. Thanks. Dave
PostPosted: Wed Jul 21, 2004 10:49 pm
Super Six= the slants equiped with a two barrel carb from '77 to '83 in cars and trucks.
BBD=Ball and Ball Dual throat carburetor. Ball and Ball is a name Carter used.
I still havn't done the upgrade either. With my little 1920 getting me over 20MPG on the freeway and around 15 in town, plus letting me run 70-75 all day if I need it to, I'm in no hurry. The extra power would be nice, but timing changes, distributer recurving and playing with the carb., exhaust, adding a clutch or electric fan frees up a good amount of power also. When your talking an engine that makes 100-110net HP, every bit, no matter how small, helps.
 Post subject: Thanks
PostPosted: Thu Jul 22, 2004 9:06 am
Thanks so much for the definitions. Now where did I put that checkbook?
Thanks again for your time. Dave
Users browsing this forum: Amazon [Bot] and 1 guest
