It is currently Tue Nov 03, 2026 2:25 pm
PostPosted: Sun Jun 28, 2026 3:11 pm
I am reinstalling the original windshield with a new gasket on my 76 D100.
Factory service manual says to use no lubricant but mineral spirits, but I have never heard of using mineral spirits to install a windshield and I am wondering if anyone is aware of a better product currently on the market to ease windshield installation.
Any suggestions?
PostPosted: Sun Jun 28, 2026 4:26 pm
Car Model: '23 T-bucket
Maybe the same stuff that tire busters use?
Roger
PostPosted: Sun Jun 28, 2026 4:38 pm
Possibly, but that stuff is *messy.* I am hoping for a product that can go in a spray bottle, such as dish soap, although I have read warnings against using dish shop because it leaves salts on the paint that will degrade things over time.
I might just try some vaseline, although i have read that is not good, either.
PostPosted: Sun Jun 28, 2026 7:13 pm
I might be tempted to use silicone spray.
Or I might be tempted to follow the FSM instrux and use mineral spirits.
PostPosted: Sun Jun 28, 2026 7:39 pm
Question (although probably the "opposite" question to Reed) along similar lines... I have a few good OEM windshields for these trucks in the attic. Who makes the best gaskets/ seals for all the glass in a D150 cab?
I need 2 windshield gaskets, actually need every piece of rubber made for an 80s 2 door conventional cab for one of them.
PostPosted: Sun Jun 28, 2026 10:27 pm
Dan-
Yes, I know, I will probably go with mineral spirits.
Don-
Check out dodgeconnection.com
PostPosted: Mon Jun 29, 2026 10:04 am
I used dawn dish detergent in a spray bottle on my car. Worked fine and dandy. No way I'm using mineral spirits around brand new paint jobs. I know how that would end for me!
PostPosted: Wed Oct 28, 2026 10:30 pm
Car Model: Colt
movie box apk
Any suggestions?
Once the windshield and new gasket are successfully lubed and roped into place, should a non-hardening windshield sealer be injected between the glass and rubber or rubber and body?
PostPosted: Thu Oct 29, 2026 4:20 am
should a non-hardening windshield sealer be injected between the glass and rubber or rubber and body?[/quote
The glass shop that put mine in said not to use anything if you have a new gasket and a clean lip. I never had a leak @ 10 years later.
PostPosted: Sun Nov 01, 2026 11:38 pm
Interesting. I used a new gasket and had a clean lip and it leaked. I am still finding spots to squirt butyl under the lip of the gasket. I think I have most of the leaks stopped.
