It is currently Thu Nov 26, 2026 3:42 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Sat Nov 07, 2026 1:11 pm
And how fast did Mike run with that car? I just remember I couldn't believe it ran as fast as it did with a 2 barrel and no head /intake work. Pretty amazing. :D :D
PostPosted: Sat Nov 07, 2026 4:26 pm
I bet it was cast crank and not forged too!
PostPosted: Sat Nov 07, 2026 4:36 pm
Thanks Zilla, good info.
PostPosted: Sat Nov 07, 2026 11:10 pm
Rick, I think he got it into the 14:20s before they gave him horsepower back and charged the indexes.
Greg, yes, cast crank. It has to match the year claimed.
Thank you Stan. You know I am Mr. Helpful. :mrgreen:
PostPosted: Mon Nov 09, 2026 9:20 am
Thanks all and appreciate the Info Slantzilla. Now that's a new piece of information I have not seen. I did not know W was for 4 cylinder cars. Digging up rules and info is challenging I haven't been getting all the details.
This might take some serious work to go V/SA 15.50 is asking a good bit now.
I guess I need to dig deeper for more accurate, detailed rules but getting in touch with anyone specifically at NHRA can be very slow or not happen at all!
Dealing with them over this last national and now with contingency payout I earned, they are poor at contacting u back with any questions or issues I have. Like for example no one wants to reply to correct my missing contingency for Trickflow heads on my SBM.
In between now and the next year of parts collection I'll probably take this car out for a few street class races somewhere in between running my duster bracket car. Should be fun. I'll look u all up if u are ever somewhat in my region.
Thanks again everyone for the info,
PostPosted: Mon Nov 09, 2026 9:32 am
You're welcome. I just checked to make sure I didn't steer you wrong.
• Weight Break: The W/Stock class operates at a weight-to-horsepower ratio of 24.00 lbs/hp (the lowest/slowest end of the regular Stock ladder, which spans from AAA/S down to W/S).
• Engine Restrictions: While higher/lighter classes accommodate V8s and various displacements, modern NHRA W/Stock is restricted to 4-cylinder engines that fit the 24.00 lbs/hp factor.
I've got a 78 2 door Volare that can run the 2bbl I can fix you up with. :lol:
PostPosted: Mon Nov 09, 2026 11:58 am
Where are the horsepower numbers found? I looked at the rules (which would be absolutely overwhelming to me) and didn't see the horsepower factors. I probably looked right over them. Too bad they don't allow you to run a 2 barrel in some of the lighter A bodies that didn't come with them.
PostPosted: Mon Nov 09, 2026 4:34 pm
You have to get into the guide. It explains classes, weights, and factored horsepower.
Easy as pie. :idea:
