It is currently Tue Dec 30, 2025 9:02 am
 Post subject: Where to Start
PostPosted: Mon Sep 27, 2004 6:52 am
Brought home the bone stock 225/auto 65 Valiant this weekend. It's future use is various "cruises" in the local area...no drag strips in the near future either. But...other than a good tuneup, etc., what upgrades to the engine would you suggest for a little more performance (the chrome valve cover looks good though!)?
PostPosted: Mon Sep 27, 2004 7:32 am
(1) electronic ignition
(2) larger exhaust system
(3) larger carb (you will be limited by your throttle linkage--you may want to convert to a cable style)
 Post subject: Where to Start Part II
PostPosted: Mon Sep 27, 2004 6:39 pm
Reed: Already have upgrade to ignition system installed. Guess the next step is exhaust or intake. I don't really know which to begin with. Ideas?
 Post subject: ditto
PostPosted: Mon Sep 27, 2004 6:44 pm
Car Model: '63 Dart GT Convertible
those are the only upgrades I have on my dart. The difference in the way it runs is amazing. Runs great,starts great, sounds good too with Dutra duals and turbo mufflers.
PostPosted: Tue Sep 28, 2004 9:39 am
Your typical carb upgrade options are a Super Six (junkyard two barrel that makes a decent improvement) or a 390 cfm four barrel Holley on an Offenhauser or Clifford manifold. Other options include two stock carbs on a special Offenhauser manifold; Mopar's M1 two barrel kit; Pro Line Fuel's one, two, or three Weber conversions (the single one uses your existing manifold); or certain oddities from Australia that occasionally pop up on Ebay. Three Webers would be a bit wild for street use, and there's some debate about whether a four barrel is too big for a stock slant.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
