It is currently Mon Jun 15, 2026 1:58 pm
 Post subject: Dash Removal
PostPosted: Mon Oct 18, 2004 2:50 pm
I'm in the process of removing the dash from a 1972 Dodge Dart, however, the bolts located around the gauge cluster i can't seem to get to. I tried removing the gauge cluster but the the column was quite in the way, and after unbolting the column, it doesn't hang low enough. What do I do?
PostPosted: Mon Oct 18, 2004 3:13 pm
Your almost there. Remove the bolts at the firewall then the column will drop lower.
Sweet Emotion
