It is currently Sat Jun 13, 2026 1:49 pm
 Post subject: Digital Gauges
PostPosted: Tue Oct 19, 2004 9:29 am
I have a chance to score a complete dash from an `86~ish Chrysler with the digital gauges. I think these would look great on my D100. Anybody know what all I need from the donor car? I know I'll need the little speedometer sensor, but what else?
PostPosted: Tue Oct 19, 2004 9:52 am
A lot of those cars had trouble with the digital IP, so it's not the best unit.
Both the tach signal and the speed/distance sensor signal went through the logic module first, so I don't know if they will work without it.
The other inputs are straightforward, except that the sensors are often specific to the digital setup, so grab all the sensors/sending units off the donor.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Tue Oct 19, 2004 10:57 am
What about the gas tank sending unit? If its resistance is in the wrong range that could be tweaked externally w/other electronics but I'm more worried about fittment.
PostPosted: Tue Oct 19, 2004 11:04 am
The fuel sender on an 86 LeBaron has a range of 30-230 ohms, according to the information I have.
O==\=/==O
- Jim Preston
 Post subject: Hmmm, smells tricky
PostPosted: Tue Oct 19, 2004 10:03 pm
I don't know if I wanna mess with a logic module! I want digital gauges, but not bad enough to reinvent the wheel to get them. I was hoping it'd be like changing regular gauges. Guess not. :shock:
PostPosted: Tue Oct 19, 2004 10:46 pm
Dakota digital makes standalone digital gauges, and even entire dashes for some cars. But be prepaired to spend an arm and 2 legs for those. www.dakotadigital.com
