It is currently Tue May 19, 2026 3:52 am
PostPosted: Mon Dec 27, 2004 7:13 pm
Car Model: 1967 Dodge Dart GT
hey again, it appears the motor is locked up(its only been sitting 15+ years(since we moved to town, plates are 77 :lol: ))whats the best way to free it up? have heard putting penetrating oil or diesel in the cylinders, so yeah, some input is definately appreciated! thanks!
 Post subject: o yeah
PostPosted: Mon Dec 27, 2004 7:14 pm
this is our new project, 64 a-100 truck...
PostPosted: Mon Dec 27, 2004 7:29 pm
Kroil.
PostPosted: Mon Dec 27, 2004 7:31 pm
PostPosted: Mon Dec 27, 2004 7:35 pm
oic, i looked it up, thanks!
PostPosted: Mon Dec 27, 2004 8:34 pm
Pouring some ATF in the cylinders and gentle tapping helps a lot.
PostPosted: Mon Dec 27, 2004 8:48 pm
I wouldn't try it with the starter. Pull the plugs out, and remove the timing chain or pull the rocker shaft so the load of the valvesprings aren't on the engine. Then take a big long breaker bar and put it on the bolt in the center of the vibration dampner (install a bolt if one didn't come there, they did on most later slants). Give it a couple hefty jerks to see what will happen.
Get the crank turning first then worry about the valvetrain.
I just hope one of your rings won't shatter when it breaks loose. I'd hate to have a ring fragment destroy the bore completely.
Sidenote: leave it in neutral and pull a battery cable as a safety item.
PostPosted: Mon Dec 27, 2004 10:42 pm
Kroil?
Once you use it you will laugh so hard your sides hurt at the notion of ever using Liquid Wrench or any other silly kid stuff ever again.
The advice not to try cranking it with the starter is a good one. With the starter's 45:1 overall mechanical advantage over the engine, you can bend rods.
PostPosted: Tue Dec 28, 2004 6:21 am
Love Kroil. Only has one problem. Have to buy direct from the manufaturer, with a minimum quantity.
PostPosted: Tue Dec 28, 2004 7:09 am
Went the transmission fluid route on our "frozen" slant. Pulled the plugs and poured a little in each cylinder. Let sit all day. Pulled the starter and got on the flywheel (torque converter) with a large screwdriver (I know, might break a tooth, but didn't have a crank bolt or know that I could install one).
Once you break it loose and determine that it will turn freely several times, reconnect the battery and starter. Hit the starter a couple of times to "spit" the extra ATF out the open plug holes. Swab the plug tubes out with a rag, reinstall the plugs and give her a go. You might want to drain the fuel system and use fresh gas, if it has been sitting for a long time. Ours fired right off with the old gas after only a couple pumps of the accelerator pedal. It smoked like a freight train while it burned off the remaining ATF. My son and I were just happy to see it run, after buying the car with a "seized" engine. :D
Jerry
 Post subject: thanks
PostPosted: Wed Dec 29, 2004 9:33 am
thanks all, its dads truck so ill pass on the info to him and let him make the call...thanks!
PostPosted: Wed Dec 29, 2004 10:54 am
I used Marvel Mystery Oil instead of ATF which worked, but
actually it looks alot like ATF, even tho I don't know what's in it.
PostPosted: Wed Dec 29, 2004 2:05 pm
Its a mystery! :shock:
Users browsing this forum: Google [Bot] and 22 guests
