It is currently Fri Jan 02, 2026 6:26 pm
PostPosted: Mon May 23, 2005 6:38 pm
Does anyone know the lash specs for this cam?
I know .10 intake .20 exhaust is stock. I guess I'll start with these.
Thanks :?
PostPosted: Mon May 23, 2005 7:12 pm
hi, should be .028 intake, .032 exh. cam centerline 106, installed centerline 104. ron
PostPosted: Mon May 23, 2005 7:27 pm
Thanks! :)
Why is it so much bigger?
PostPosted: Mon May 23, 2005 7:55 pm
Go down to the bottom and click on slant 6:
http://victorylibrary.com/mopar/mpcam-tech-c.htm
PostPosted: Tue May 24, 2005 10:59 pm
Thanks! :)
Because that lobe profile was never ment to be used on a SL6 cam.
I have never had good luck with the Mopar 268 cam, I don't know what Mopar was thinking when they came up with it. To get a half way decent idle you have to use that wide lash... then you have a noisy valve train. :x
PostPosted: Wed May 25, 2005 6:43 am
Car Model: 1966 2D Dart
Thanks! :)
So it is not a good cam, and if it still in the shop, its maybe better to leave there?
How about Comp Cams 264?
PostPosted: Wed May 25, 2005 7:02 am
Too late. I got it in already. I'll see what happens.
PostPosted: Wed May 25, 2005 5:55 pm
Will that big a lash (.28 and .32) make it easy for a push rod to come out?
I would be afriad of one popping off.
Doug:
When you say a half-way decent idle, what rpm do you mean?
If I run a 1000 rpm idle, and I'm OK with it being lumpy, and I have a manual transmission, do you think I'll be allright?
I guess what I'm asking is, will the car be undrivable?
I just want to see what I have to look forward to. :wink:
PostPosted: Wed May 25, 2005 10:00 pm
With a manual trans and 3.23 or steeper gears, you will be OK
Idle will be 800 to 1000 RPM, you will have to "play around with the lash, initial timing setting and idle air/fuel ratio to get decent idle and off idle responce..... but once the engine is on the RPMs, watch-out! :twisted:
PostPosted: Thu May 26, 2005 6:48 am
Well I have 3.73's in the back, so that's good.
Thanks for the info. I'd still have a 1 bbl if it wasn't for this forum.
I'll play with the timing etc. It just wouldn't be fun if I just "bolted and ran" now would it? :)
PostPosted: Thu Jun 02, 2005 9:33 pm
OK
So I got it installed/broken in. I've got the lash set at .16/.18
How can I tell if the lash is too tight? I've got an OK idle. I also have a little noise in the valves.
Thanks
Users browsing this forum: Ahrefs [Bot] and 8 guests
