It is currently Sun Oct 11, 2026 9:05 pm
PostPosted: Fri Sep 09, 2005 9:20 pm
So, after 18 years under the tree in his Mom's garden, I finally managed to buy my 63 Wagon from the previous owner....having thrown a few $$$ at it, I am now in the position where it won't run....
New parts.......plugs; points; rotor; cap; leads; ballast; coil;
Rebuilt carb, new fuel & air filters...
Timing is spot on, we have spark, but it just won't fire.... :x
It kinda wants to run when you pour a little fuel through the top of the carb, so I am thinking mnaybe blocked/dirty lines?
Any tip's?
Thanks....
Dave
My NEW website's up & running...
Check out www.prophotophotography.com
PostPosted: Fri Sep 09, 2005 9:28 pm
When I first got my 64 Valiant (inheritance), the fuel line was completely clogged up......... Had to blow it out from the fuel pump side to the tank.
Fill up the carb with gas and see if it starts. Then see if you actually get fuel flow.
PostPosted: Fri Sep 09, 2005 10:07 pm
One of my friends has a small portable air tank, thats gonna be the next thing we do!!
Thanks for the tip regarding the carb tho, hadn't thought of that 8)
PostPosted: Sat Sep 10, 2005 3:04 am
Try having someone press the accelerator a couple of times while you are looking down the throat of the carb (engine off, not cranking). You should see a strong stream of fuel being pumped into the bottom of the carb throat. If not, then you probably have no fuel getting to carb.
You could have a bad fuel pump as well as clogged lines.
-Mac
 Post subject: TANKS a lot
PostPosted: Sun Sep 11, 2005 6:14 am
Car Model: '63 Dart GT Convertible
Remember, sitting that long tends to form lots of moisture in the fuel tank, creating rust. Cleaning out the lines may only temporarily solve any "clog" problems.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Mon Sep 12, 2005 11:35 am
Sitting that long, gas turns into 4 octane goo that you don´t want in your engine.
Try a hose form the suction side of the fuelpump, to a can of fresh gas, and see if that help :wink:
If it runs then, drain the tank!
PostPosted: Mon Sep 12, 2005 12:06 pm
Checking for fuel to the carb, as has been suggested, is the best bet. If that isn't the problem:
Are you POSITIVE your timing isn't 180 degrees out? That can make it almost want to run.
DAMHIK :oops:
PostPosted: Fri Sep 16, 2005 12:25 am
Thanks again for the tips, will try them all!!
Users browsing this forum: Amazon [Bot], Bing [Bot] and 30 guests
