It is currently Wed Dec 31, 2025 12:22 pm
PostPosted: Wed Sep 28, 2005 5:23 am
I want to install a oil pressure sending unit for my oil pressure gauge along with my oil pressure switch. Does someone make an adapter to hook up both on my oil pump?
Thanks,
bwhitejr
PostPosted: Wed Sep 28, 2005 5:55 am
Yes, Weatherhead makes one... It's called a brass tee fitting, and can be had in any hardware store.
D/W
If it ain't broke, fix it!
PostPosted: Wed Sep 28, 2005 7:38 am
There is also a combination switch/sender unit that'll work. Think it's even a Mopar part. Ebooger wrote about it in one of his "Mopar Action" issues; I'll see if I can prise the P/N out of him.
 Post subject: switch
PostPosted: Wed Sep 28, 2005 7:54 am
i think the one out of a jeep wrangler will work as they have a light and a gauge. the one i did was on a 90. can't remember how the wiring works though...
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Wed Sep 28, 2005 2:54 pm
You can make a tee fitting with all related adapters / Pats from any hardware store. Use teflon tape and tighten it down snug!
GReg
PostPosted: Wed Sep 28, 2005 4:56 pm
Ebooger says "I never actually confirmed that the dual-sender works with the old gauges, but P/N 5233396 is the best shot."
