It is currently Sat May 02, 2026 2:34 am
PostPosted: Tue Dec 13, 2005 4:47 pm
I found the seat ive been looking for the split bench with the arm rest but it's in a fury II before i pick it up does any one know would it fit fit in a duster? still has the tracks
PostPosted: Tue Dec 13, 2005 4:54 pm
The bench seat in my 64 was a bit too close to the steering wheel even when it was all the way back.........
So I got some angle iron and bolted it to the seat tracks then bolted that into the car to move the seat back a bit for more leg room (seat adjustment still works, it's just offset everything back a bit)
I would think you could do the same thing to make it fit
PostPosted: Tue Dec 13, 2005 6:40 pm
The Fury II is a rather large car, my guess is that the seat will be a lot wider. You should measure the overall width of the seat and the space where you want to put it. It wouldn't be a bad idea to measure the depth and height as well. I'd be surprised if it will fit.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
