It is currently Thu May 07, 2026 9:21 am
PostPosted: Tue Dec 13, 2005 4:47 pm
I found the seat ive been looking for the split bench with the arm rest but it's in a fury II before i pick it up does any one know would it fit fit in a duster? still has the tracks
PostPosted: Tue Dec 13, 2005 4:54 pm
The bench seat in my 64 was a bit too close to the steering wheel even when it was all the way back.........
So I got some angle iron and bolted it to the seat tracks then bolted that into the car to move the seat back a bit for more leg room (seat adjustment still works, it's just offset everything back a bit)
I would think you could do the same thing to make it fit
PostPosted: Tue Dec 13, 2005 6:40 pm
The Fury II is a rather large car, my guess is that the seat will be a lot wider. You should measure the overall width of the seat and the space where you want to put it. It wouldn't be a bad idea to measure the depth and height as well. I'd be surprised if it will fit.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Ahrefs [Bot] and 1 guest
