It is currently Tue May 12, 2026 8:04 pm
Post new topic  Reply to topic  [ 37 posts ]  Go to page 1 2 3 Next
PostPosted: Mon Jan 23, 2006 2:15 pm
What if any motors come close to the /6 for toughness? I have 2 picks.
The straight 6 from Jeep. It is a AMC design but its a good performer and durable and easy to work on. It comes real close to the /6.
Ford had a straight 6, a 300 C.I.D monster. This is thought of only as a truck/Van motor. It is super tough. But i think you could get this for mabey 2 years (69,70?) in a real stripped down Galaxie/LTD.
Thes are the only 2 that comes close that I can think of.
comments..................
 Post subject: Hmmm...
PostPosted: Mon Jan 23, 2006 2:30 pm
I think you'd just have to leave it up to the various 'pro/con' of each one as they all have some strengths, and all have certain weaknesses...
Your Competition list should be:
Ford 250/300
Chevy 250
AMC/Jeep 242/4.0L
You could add a few others if you went outside the "Inline 6" realm...but each has it's own peculiarities...
"Although I do like the fact that the 4.0L in a Grand Cherokee has about as much umph and better mileage than the 4.7L in the same platform..."
 Post subject: Toyota Land Cruiser
PostPosted: Mon Jan 23, 2006 2:33 pm
The Toyota Land Cruiser Inline 6.........
 Post subject: 250 straight 6
PostPosted: Mon Jan 23, 2006 2:35 pm
I didn't mention the chevy and ford 250 Straight 6 because i didn't think they were in the same ball park as the /6.
But it seems the Jeep 4.0 comes close to being as "good" as the /6.
And the V6's are a totally different animal. i'm just referring to straight 6's.
 Post subject: Re: Toyota Land Cruiser
PostPosted: Mon Jan 23, 2006 2:39 pm
I didn't mention the rice motors because though some of them are very good, most of them are newer fuel injection type and I would put them under a different classifacation then the American motors which were all designed in the 60's.
PostPosted: Mon Jan 23, 2006 2:51 pm
I was thinking of the older Land Cruisers..............
The original came out in 58; F135 @ 236.7cuin then there was a F155 at same displacement in 71. Used until 1974 when replaced by 2F (improvement of F engines)engine @ 257.9cuin (used till 87), then 3F (88-92) then forget it after 93 as it's a whole new engine family......
So I'd say the F135's & F155's count, and maybe the 2F (with an outside possibility of 3F)
PostPosted: Mon Jan 23, 2006 3:02 pm
I stand corrected....but I think that motor would be in a different class, the American motors are much more plentiful and the parts are still easily avaiable and CHEAP.
PostPosted: Mon Jan 23, 2006 3:06 pm
You asked for toughness................
PostPosted: Mon Jan 23, 2006 3:07 pm
And it was a production motor, not a custom or one-off...
PostPosted: Mon Jan 23, 2006 3:15 pm
Things that determine the "goodness" of an inline 6:
7 main bearings, forged crank/rods, timing gears, 12 port head, EFI potential, breathing, displacement potential, trans availability
The 300 Ford has all of these.#1 ! (imagine a 340" EFI 5 speed in a Fairmont wagon....it all bolts up.)
The AMC comes a very close second...(only 2nd on displacement has all the rest) EFI 4.0 5 speed in a Spirit AWD
Pontiac OHC....no EFI....funky belt
Chev 6 is Fourth because of siamesed intake ports.(Does have lots of trans possibility)
Toyota is next only because it is a Japanese Chev 6. and has less dispacement(no 292)
slant six ( 5 mains , chain drive cam, oil pump woes, small displacement)....but they came in a way better car than the others with mebbe the exception of some AMCs(Spirit AWD, Gremlin)
I had a 61 Falcon Coupe with C4/convertor, 305" Ford 6, Offy 600 Holley, Crane Cam, Clifford Headers. 8" rear with gears. Im sorry but no slant in the same tune would touch it. It bent the car.
PostPosted: Mon Jan 23, 2006 3:38 pm
Do you know what cars the Ford 300 came in? i think its size (length) would be a problem except on full size cars? I'm a bolt-on car guy, the reason I like the /6. There aren't to many cars with the AMC 4.0 . I know there are plenty of jeeps,but in the newer ones they are realy jammed in the engine compartments.
Do you know which cars had the Ford 300 in it?
PostPosted: Mon Jan 23, 2006 3:48 pm
The 240/300 was a split motor....cars got the 240 yechh!,,,and trucks got the 300.
The 240s came in about 66-70 big Fords, I built mine using a 240 out of a 66 Galaxie taxi. I then ordered the "Select" forged 300 crank and rods they used in garbage trucks,,,,BIG garbage trucks. I also used 4.030 Chev V8 pistons to get 11 to 1 CR....FE series Valve gear. I used the garbage truck oiling system....a Pinto torque convertor and V8 C4...I never broke anything on that car,,,daily driver, low 13s in 1975. A similar setup owned the NHRA H/MP record at 11.28.
Now I would add a 5.0L Mustang EFI setup and a 5 speed. Yikes......and get rid of that Pinto 'vertor.
PostPosted: Mon Jan 23, 2006 4:26 pm
Bruce Sizemore owned the H/MP record for years. Wasn't his Ford Maverick named 'Preparation H'?
I saw a Holman-Moody intake for a 300 Ford at the Turkey Rod Run in Daytona a few years back, the HyperPak looks mild in it's appearence compared to it.
Slant Cecil
PostPosted: Mon Jan 23, 2006 5:21 pm
So you're saying If i had a 67 Mustang with a 240 6 in it I can replace it with a 300 and it will pretty much "bolt in"?
PostPosted: Mon Jan 23, 2006 5:28 pm
Yes, IF it had a 240 in it, a 300 would bolt right in.
If a 240 is there, someone put(shoehorned) it in.
Mustang got the smaller 200 and 250 motor.
small6 series;
144
170
200
250
big6 series;
240
300
Slant Cecil
Users browsing this forum: Google [Bot] and 7 guests
