It is currently Mon May 04, 2026 5:44 pm
PostPosted: Sat Apr 02, 2005 9:08 pm
Ok, what happened and what I did.
My gasket that goes between exhaust manifold and muffler tube broke up, so I decided to remove it and put a new one, after some hard work (because of thing space) I put the new gasket, and test it, everything was working fine, until some minutes later (with engine working) a smell of burning reach me.
I opened the hood and the smell was there, I think it comes from the new gasket, what can be??
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Sat Apr 02, 2005 9:38 pm
the gasket probably burned out again. You might have accidentally warped the flange on the exhaust manifold when you replaced the gasket.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun Apr 03, 2005 3:04 am
try putting some high temperature sealer on it, and make sure both of the surfaces are clean and meet up good..
70 Plymouth Valiant 4dr
PostPosted: Sun Apr 03, 2005 4:32 pm
I donno, the exhaust manifold flange is about ten times the thickness as the header pipe flange, so I doubt that's warped.
It is normal for a new gasket to stink a little bit when used for the first time. If it is a strong odor then maybe youre running lean and the manifold is getting too hot. Take your spark plugs out and look at them (read the color), or take a picture and post it here, and check your exhaust joint for leaks with the car cold (feel with your hand for air chuffing through) and be careful.
 Post subject: All set.
PostPosted: Sun Apr 03, 2005 7:32 pm
Thanks steponmebbbboom!!!, I checked it cold, and clear alll the surrounding of the gasket, also check my spark plugs (cables) and I need to retire them, I will buy some new set tomorrow, but the smell has stoped, also odor was strong ´cause I used two gaskets instead of one, but I have used the car form one hour after cleaning everithing from exhaust manifold and muffler tube. I found very little pices of charcoal, so that tells me that I really need to clean my engine.
But the important thing is that burning smell has gone, this was the firts time I did this operation, also notice that my choke has stop working.
Valiant Duster 1971
PostPosted: Sun Apr 03, 2005 7:35 pm
:shock: Well as long as you are grinning, I guess my work here is done.
 Post subject: About he Choke.
PostPosted: Sun Apr 03, 2005 7:54 pm
Since now is getting cold in the mornings here, I didn´t notice that my choke is not working until now, I wonder what can be? and since when it stoped working?
Valiant Duster 1971
