It is currently Thu Jan 01, 2026 10:17 pm
 Post subject: pistons
PostPosted: Wed May 10, 2006 8:38 pm
hello there folks. i'm attempting to stroke my slant six with the long rods and the 2.2 pistons. there is one problem i'm having a hard time finding 6 of them. they are the keith black pistons. part number kb239. does anybody know where i can purchase these online?
PostPosted: Wed May 10, 2006 8:49 pm
www.summitracing.com
search for
uem-kb239 and you'll get some options
PostPosted: Wed May 10, 2006 8:51 pm
thanks alot
 Post subject: Re: pistons
PostPosted: Thu May 11, 2006 9:28 am
Hmmm.... what am I missing here ??
What crank are you using, where did you get it ??
Would like more details .. ( I might be interested in this mod )
PostPosted: Thu May 11, 2006 10:46 am
Mel,
Check out this link from the articles section. http://www.slantsix.org/articles/stroking/stroking.htm
Basically using the longer rods from a 198 slant six in a 225 block/crank with 2.2L (four cylinder) pistons.
Brian
PostPosted: Thu May 11, 2006 10:56 am
http://www.forwardmotioninc.com/
Try these guys as well.
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
PostPosted: Thu May 11, 2006 11:35 am
Mel,
Brian
OK..unless I've missed something here, you're not actually Stroking
this engine but taking advantage of these parts to get a better
compression ratio ??
I don't want to "Rain on your Parade", but I'm not sure its worth the
effort when you could order a set of Hi-Compression pistons from one
of the after-market manufactures.
I don't see the advantages to this mod.
PostPosted: Thu May 11, 2006 12:00 pm
http://www.hotrod.com/techarticles/pit/index14.html
Yeah, HR magazine sucks, but this may have some good background on the issue.
PostPosted: Thu May 11, 2006 12:31 pm
the benifit is with the long rods you can use lighter pistons
PostPosted: Thu May 11, 2006 12:48 pm
Ummm........ OK...........
I'm not looking to get into any major/minor dis-agrrement on this ....
I'd just like to understand the thinking behind it.
Unless this is an All-Out race car it seems to me to be alot of bother
for a Street-Cruiser.
Just because something 'Can' be done doesn't necessarily mean it
should be done.
Its been more than 30 years since I built an engine, I guess the way
some things are thought about / percived could have changed.
Generally I look at things in as "Cost vs. Gain" .
PostPosted: Thu May 11, 2006 1:45 pm
OK..unless I've missed something here, you're not actually Stroking this engine but taking advantage of these parts to get a better
No, this is nothing to do with compression ratio, and the lighter piston weight mentioned by 70Valiant is only a side benefit. The real benefit to the longer rods is a more favourable "rod ratio" (properly: rod:stroke ratio) which means less sideloading of the piston against the bore (=reduced friction and bearing stress), and longer piston dwell time at TDC (=better resistance to detonation) and at BDC (=better cylinder scavenging).
PostPosted: Thu May 11, 2006 2:18 pm
I think you also get rid of the problem of having the pistons way down the hole with the 2.2 pistons.............
