It is currently Sun Dec 28, 2025 2:43 am
 Post subject: new rad
PostPosted: Mon Oct 30, 2006 12:43 pm
just wanted to know the best procedure for making sure all the junk is out of the coolant passages, before i replace the rad, only to potentially clog it again a month down the road.
PostPosted: Mon Oct 30, 2006 1:00 pm
Even disassembling the engine completely and having it hot tanked doesn't always get all the junk out. A cooling system flush can help, but won't get out sediment and other junk in the bottom of the water jacket. A coolant filter in your upper radiator hose it probably your best bet. I had a 2-piece aluminum filter from JC Whitney, but could never get it apart to change the screen.
http://www.trophymustang.com/gano-filter-p-986.html
PostPosted: Mon Oct 30, 2006 3:11 pm
cool, thanks
