It is currently Mon May 04, 2026 1:49 am
PostPosted: Mon May 07, 2007 6:20 am
Duster Hedders
I'm in the midst of installing headers in a '74 Duster.
I'm keeping the slant 6 intake.
Headers are Clifford Tri-Ys.
I know some of you out there must have done this.
1. How did you all handle getting heat from the new headers to the bottom of the old iron intake?
2. ow did you rig up the bottom of the throttle linkage bracket that attached to the old exhaust manifold?
It looks like I'll have to do some fabrication unless somebody has a better idea--a distinct possibility.
thanks for your input.
how did you all handle getting heat from the headers to the bottom of the old iron intake?
PostPosted: Mon May 07, 2007 7:25 am
I ran headers for years. No heat to the intake. Start-up and warm up will take some getting used to, but I drove mine in sub zero weather with no problems.
You will have to fabricate some brackets. :shock:
PostPosted: Tue May 08, 2007 6:44 am
Mopars-n-More has come up with kit for trans linkage to use with after market headers.This will hit the net soon
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
