It is currently Fri Jan 02, 2026 6:00 am
 Post subject: loose distributor
PostPosted: Mon Mar 24, 2008 1:23 pm
working on a 64 Dart Gt with a 225 the distributor has 2 adjustments one on the block that is tight and one seen from below that lets the body of the dist move. is this normal? is the vacuum supposed to move this or should it be tight? This is the first slant I,ve worked on, we added a 390 Holley on a Clifford intake and headers to a dual 2" to 2 1/4 out the back
would appreciate any help you all could give
Thanks in advance
working on a customers 225
PostPosted: Mon Mar 24, 2008 2:49 pm
Both need to be tight!
The vacuum advance does its work internally and no external movent is seen.
Sounds like a nice package! :D
I hope to get there one day...
 Post subject: anoter question
PostPosted: Mon Mar 24, 2008 3:21 pm
Thanks, how do you determine where the bottom bolt is set at, and how do you tighten the bolt down in the car
Thanks Mike
PostPosted: Mon Mar 24, 2008 3:43 pm
I don't know if theres room to reach under there and get to it without pulling the distributor. I'm pretty sure its a 7/16" bolt. You set it to your liking. If you wan't more timing advance and the distributor is turned as far as it can, thats when you loosen the bottom bolt and turn the bracket so you can turn the distributor more to get more or less advance. Theres no set spot for it.
 Post subject: Thanks
PostPosted: Mon Mar 24, 2008 5:09 pm
Thanks for the response, I just made my own wrench, modified 7/16 wrench and a long extension welded together works great
Thanks Again Mike
 Post subject: That helped me a lot!!!
PostPosted: Thu Apr 17, 2008 10:38 am
Thank you for your reply. I have a '63 Dart GT and have not been able to get the timing to the 2.5 degree BTDC point, and the distributor was turned all the way but still at about 10 BTDC. I couldnt figure out how to get it to turn more, and tried loosening the dist and pulling up the rotor to have is skip a tooth on the bottom of the dist driveshaft. Not such a good idea! Thank you for the info.
1963 Dart GT
PostPosted: Thu Apr 17, 2008 10:49 am
Car Model: 1974 W100; 72 Dart
Somebody posted a tool made specifically for this purpose....give me a minute.
sb
 Post subject: Should've known....
PostPosted: Thu Apr 17, 2008 10:51 am
It was SSD:
http://www.slantsix.org/forum/viewtopic ... tor+wrench
sb
