It is currently Tue May 26, 2026 11:47 am
PostPosted: Tue Sep 09, 2008 12:33 pm
my plymouth duster has no overflow tank for the radiator, what is your idea about it?
should I install an aftermarket tank or is it a waste of time and money an is that tank not really neccesary?
Moving to the U.S??? no thank you! I'm livin' in the land of free healthcare!
PostPosted: Tue Sep 09, 2008 1:03 pm
I have used regular plastic soda bottles as a catch can, with the tube down to the bottom of the bottle. Or, I've used a Nalgene chemical wash bottle with a tube integral. Doesn't hurt to have it, and it's almost free.
PostPosted: Tue Sep 09, 2008 1:44 pm
You can not pass tech without one.
PostPosted: Wed Sep 10, 2008 8:14 am
thats not a problem. I live in Europe. different rules apply.
PostPosted: Wed Sep 10, 2008 2:41 pm
If you have the big top tank, you don't need the overflow; just don't fill the water to the neck.
PostPosted: Fri Sep 12, 2008 8:48 am
Having an overflow keeps your radiator filled to the brim at all times/all temperatures which can be seriously beneficial over the long term for avoiding having air help cause corrosion inside the radiator.
I just have a radiator fluid container with a hole punched in the cap that the tube goes down into. It's wedged in right behind the grill to the side of the radiator.
PostPosted: Fri Sep 12, 2008 11:57 am
Fab one up for the simple reason you won't have coolant dripping onto the ground...
PostPosted: Fri Sep 12, 2008 1:47 pm
ok!
I'll go for the bottle then.
I've found a mopar reservoir lying in the trunk, which made me look for the place where it should be mounted and then I found out that this car did not have one
so all I need to do is find a place to mount it, fab some bracket and install it.
thanks for the advice guys!
Alain
