It is currently Fri Jan 02, 2026 10:54 am
 Post subject: What A Disaster!!!
PostPosted: Sat Sep 04, 2010 9:15 pm
I have a plum unborded 225 iron block and was just drilling out oil passages through the cam bearings, but god knows what was going through my head when I thort I hadn't drilled through enough but I went through the block! This is so embarresing to tell but hey we all make mistakes, $#!+!
Should I get the hole welded up?? Or start again and find a new block?
PostPosted: Sat Sep 04, 2010 10:07 pm
if the hole came out in a place where access is OK,tap a thread into the stray hole and fit a plug.
my 2 cents.
regards,Rod :?
PostPosted: Sat Sep 04, 2010 10:25 pm
You just drilled through the wall of the oil galley right? Drill and tap it for a 1/16 or 1/8-NPT plug and press on.
PostPosted: Sun Sep 05, 2010 7:06 pm
Is the hole in the front or back?
If it's in the front, maybe you can make a plug with a tiny hole in it to spray oil on the timing chain...........
PostPosted: Sun Sep 05, 2010 8:14 pm
I would plug it and then tell know one. :wink: :wink:
85 d-100 HEI 2BBl
06 Toyota Corrola
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
