It is currently Thu Jul 16, 2026 12:47 pm
PostPosted: Sun Feb 20, 2011 11:14 am
I am looking for a good quality aftermarked valve cover that will not leak. Any leads or suggestions will be greatly appreciated.
I know about overtightening and straightening out the contact surface but mine is so damned old and worn out and so am I. There has to be better way.
Frank 8)
PostPosted: Sun Feb 20, 2011 11:18 am
nada ....there are no good aftermarket valve coversfor slant....find a good used stock one...either paint and send it to chrome shop if you a chromed one
PostPosted: Sun Feb 20, 2011 11:41 am
The cast aluminum Offy valve cover will be considerably stronger and will lighten your wallet significantly. Also, you have to do some custom work to use a PCV valve; it's been discussed at length.
PostPosted: Sun Feb 20, 2011 1:55 pm
Sure there is: the Offenhauser aluminum item. But a stock valve cover in good condition with a good gasket seals up just fine. The cheap chrome aftermarket ones are Chinese garbage, though.
PostPosted: Sun Feb 20, 2011 6:11 pm
There is also a brand new aluminum cover from aussiespeed.com, but I do not know anything about availablility in USA yet. They come in raw, polished and black painted versions.
You can also take a look at the aircraft quality silicone rubber valve cover gaskets from realgaskets.com, mentioned in this thread.
Olaf.
Aspenized
PostPosted: Sun Feb 20, 2011 7:37 pm
correct me if I am wrong ...but the offy alum one needs work to work right
PostPosted: Sun Feb 20, 2011 8:43 pm
6 Pack Dart
I have a Clifford (copy of Offy) and I used 2 neoprene glued together with contact cement. You will need longer cap screws or 1/4 20 bolts.
Richard
Users browsing this forum: Amazon [Bot], Bing [Bot] and 6 guests
