It is currently Fri Dec 26, 2025 11:26 pm
 Post subject: Fuel tank
PostPosted: Fri Dec 02, 2011 7:18 am
Hi,
Fuel tank on my A-body is getting rusty, it also has a little gunk inside (varnish, dirt etc).
My plan was pull it, clean it out replace any consumables (o rings etc), change the sock, check the sender unit etc, de-rust the outside and then repaint it. But I believe it is so far gone that anything I do will not be a permanent fix.
Then I was told about "fuel cells'
http://www.ebay.com.au/itm/FUEL-CELL-PO ... 989wt_1164
Does anyone know if I can get one of these and place it where my current fuel tank is? Or can I only mount one in the boot?
I imagine they come with a built in fuel sender unit, can I link this one up to current A body instruments? or do I need a new gauge?
Is there place online that sells replacement fuel tanks?
Thanks. I couldn't find much information on the internet :/
PostPosted: Fri Dec 02, 2011 8:41 am
Fuel cells mount inside the trunk. By the time you get one with the proper sender and get it mounted up you'll spend what a replacement tank goes for, plus you won't be able to use your trunk anymore. :shock:
PostPosted: Fri Dec 02, 2011 11:52 am
That's a 40 liter fuel cell....of the top of my head that's 11 gallon right?
You can get stock replacement fuel tanks (16 gallons) all over the place! Check www.rockauto.com And they're quite a bit cheaper than fuel cells.
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
