It is currently Thu May 14, 2026 6:01 pm
 Post subject: Help with engine ID
PostPosted: Sat Mar 16, 2013 1:40 pm
I am trying to figure out what I have here. It's a '63 Valiant convt. slant 6.
The stamping below the # 1 plug reads:T22 11 08 2.
The stamping on the side if the block reads:2202857-4.
The vin# on the registration reads: 1432537669.
I don't understand why there are 3 different numbers.
PostPosted: Sat Mar 16, 2013 3:18 pm
The one on the pad is for the factory to stamp for date of manufacture, type and use of the engine.
The casting on the drivers side of the block is the part number you will find in the parts catalog.
To match with the VIN, you will be looking for the stamped machined pad on the passenger side of the block just above the oil pan rail... it will have some of the VIN numbers (like last 6 or 8 or so depending on year of vehicle).
The tranny will also have part of the VIN stamped on it as well and location will vary depending on an automatic vs. manual tranny.
Good Hunting.
-D.idiot
PostPosted: Sat Mar 16, 2013 3:23 pm
225 engine manufactured on Nov 8th 1962 I will give you the vin break down later when I am at home. Take a magnet to the block and see if its aluminum. Give us the info off the fender tag on the drivers side inner fender.
Brian
63 Plymouth Valiant Wagon
PostPosted: Sat Mar 16, 2013 4:12 pm
The magnet sticks to the block.
fender tag reads:
1576813
A
3 1130 5022 145 795 ppp
PostPosted: Sun Mar 17, 2013 6:28 am
Look here:
http://www.mymopar.com/index.php?pid=31
PostPosted: Sun Mar 17, 2013 1:15 pm
Ok the vin tells me its a 63 valiant signet convertible made at the Hamtramck MI. plant
VIN #
1= Valiant 6
4= Signet 200
3=1963
2= Hamtramck MI. plant
537669 = vehicle off the production line that year numbers normally start at 100,000
ppp = paint color red roof, body and side sweep
795=trim buckets vinyl red
145= body valiant6 signet 200 convertible
1130 production date friday november 30th 1962
5022 shipping order number
the other numbers are it's options they have a corresponding letter or number above them i will need them to break down the options
Brian
