It is currently Thu Jan 01, 2026 12:05 pm
PostPosted: Sat Oct 18, 2003 6:15 am
The only replacements available to replace the 2 bbl carburetor is a Carter BBD which every Jeep owner will tell you sucks with a capital "S" and the Holly 32/36 which will fail miserably in smog testing states.
!983 D-150 2 wheel drive with 225 CID 435 4 speed. Long bed
PostPosted: Sat Oct 18, 2003 11:07 am
Direct Bolt ons:
Carter BBD (small version)
Holley 2280 (replaced Carter during the smog era)
$$$ -Holley 2D Pro-jection TBI unit...(you wire and install and tweak)
some adaption and 'dialing in required'.
Use Mr. Gasket #1937 adaptor plate:
Holley 2300 350 cfm...
Using a couple of adaptors the Holley 5200/DGAV clone can be used:
PostPosted: Sat Oct 18, 2003 3:12 pm
Just out of curiosity, why do Jeep owners dislike the BBD? and what applications used the BBD?
PostPosted: Sat Oct 18, 2003 3:48 pm
That is one good looking ride.
I have worked on jeeps most of my life and the Carter BBD was known as the worst carb ever installed on a straight six motor. The carb is computer assisted. The metering rod located in the base of the carb was used to adjust the idle mixture. Very poor idea. Never worked. Often froze in place. Was considered a high maintenance setup The Carter used a stepper motor to control those rods. If you want to use a Carter without the computer that is possible. Just move the needles into the "full rich" position before disabling them.
Thanks,
Fran
PostPosted: Sat Oct 18, 2003 4:44 pm
The biggest problem with the early BBD's like they used on 318's and Slants is they wear out the throttle shft bores in the base plate and leak vacuum. Then they won't maintain idle for crap.
I used one on my Duster and really liked it. :shock:
PostPosted: Sat Oct 18, 2003 6:31 pm
The problem wasn't the carb then it was that some egghead decided to try to operate it with a crappy primitive computer.
