It is currently Fri Jun 19, 2026 12:06 pm
 Post subject: Droolin "w" autolite
PostPosted: Fri Apr 25, 2008 9:08 pm
I just got the 170 "w" super 6 intake running a few days ago, parked it till I have more time this weekend.
I noticed it had autolite 45 plugs. They were using the squash ring that comes with the plug. It has drool tubes and I thought I read a post where someone stated,== Throw away the squish ring if you have the drool tube heads.
Throw it away, Is that tryed and true?
How about autolite 45's. Correct plug.? G/6
PostPosted: Fri Apr 25, 2008 9:22 pm
Autolite 985s are better...........
What year is the engine?
Early engines used the ring and the tube, later engines just the tube.
PostPosted: Sat Apr 26, 2008 4:52 am
What do you consider later?
Is the 985 the extended tip?
PostPosted: Sat Apr 26, 2008 7:05 am
'60-'62 heads: Use the crush washers.
'63-'74 heads: Remove and discard the crush washers.
Autolite 45s aren't right. Use NGK #ZFR5N; long extended tip, correct heat range, and significantly better quality than Autolite (which in turn is considerably better quality than Champion).
PostPosted: Sat Apr 26, 2008 8:57 am
There I go,!!! Thanks, -G/6
PostPosted: Sat Apr 26, 2008 2:44 pm
985 is the extended tip......
There's also a platinum version of the 985.........
PostPosted: Sat Apr 26, 2008 7:47 pm
Why use crush washers on 60- 62 heads?cant figure out why you want them on any aluminum tubes,got over 10,000 miles on ngk,s,on my 62 correct SPECIAL head on my aluminum block,they look like new,not adding washers or changeing plugs,WHY 60-62 heads? BAFFELED.Mark
PostPosted: Sat Apr 26, 2008 8:07 pm
Because '60-'62 heads don't have the right counterbore that puts the plugs in the right place without the crush washers. This was a change made at the start of '63 model production. See here .
PostPosted: Sat Apr 26, 2008 9:15 pm
I call BULLPUCKY,i will remove rings on the next set of plugs i put in,probabaly 20,000 miles from now,unless i have any issues,I just dont buy into this,MY OPINION,,,,stock aluminum block 62 signet,2 ,1 barrels,duetra duals,18.23.in the quarter at Vegas,3055lbs with me in it,stereo stuff probably 75 lbs,mark
PostPosted: Sun Apr 27, 2008 6:45 am
I call BULLPUCKY
OK, whatever you say. The factory went to a great deal of trouble to publish a great deal of paper showing the difference in cylinder head casting, explicitly calling for the use of the washers in '60-'62 heads and not in '63-'74 heads, but I guess your "BULLPUCKY!" opinion carries more weight than a stupid bunch of engineers.
How 'bout those same dumbcluck engineers having changed the connecting rod oil squirt hole location for '63, and publishing a similar volume of paper explaining that on '60-'62 engines the hole has to face one direction, and on '63 up engines it has to face the other direction? Can we get your expert assessment of the BULLPUCKY! factor on that one?
:roll:
PostPosted: Sun Apr 27, 2008 7:52 am
I can't remember if I used the rings or not when I change mine. If they have rings attached I would have used them.
PostPosted: Sun Apr 27, 2008 8:58 am
That's exactly why "Blah blah I'm gonna take 'em off because the factory engineers were full of bullpucky blah blah" is silly: It takes more work for the owner of a '60-'62 head to do it wrong (remove the washers) than to do it right (leave 'em on), because many spark plugs available today (NGKs, for example) have the washers attached such that you have to do some actual work to remove them. It's worth removing them on a '63-'74 head to make sure the plug's in the right position and doesn't run hotter than it oughtter.
If you do it wrong (use the washers on a '63+ head, omit them on a '60-'62 head), the car won't lurch to a halt and the engine won't blow up, but for such a minor amount of effort, it's worth doing it right.
PostPosted: Sun Apr 27, 2008 12:25 pm
Dan, where have you been, brother? The board has seemedempty without you.
PostPosted: Tue Apr 29, 2008 10:31 pm
After doing some checking,MY stamped, SPECIAL ,head for the aluminum block,is the same as 63 later heads,as far as spark plug holes go,So ALL 60-62 heads are not created exual,,bulletin doesnt meantion the SPECIAL head,they are different.so i still call bullpucky for my car,mark
PostPosted: Tue Apr 29, 2008 10:51 pm
And the squirt holes on aluminum block rods are supposed to be pointing the other way,compared to a 60,61,62 iron block motors,I am sure you knew this from THE bulletins,plus the fact that the SPECIAL head was the same as the 63ish head as for the spark plug holes.Rings removed,runs perfect,Mark
Users browsing this forum: Bing [Bot], Google [Bot], MDchanic and 3 guests
